Buck Hollow Lawn Care
- Jan 29, 2012
- 5
- 19
Anyone have or used a toro timemaster 30" walk behind? What do you think?
We are experiencing a very limited supply of these (got some more yesterday), however of the first shipment we got, two of our professional landscape customers decided to purchase them for commercial use.
It was explained to them that the Toro Timemaster is a homeowner machine and not designed for commercial landscaper use. They bought them any way and we will be monitoring how they hold up over this season to see what, if anything, fails on the unit.
As I have stated previously, there is some buzz that Toro will be releasing a commercial variant of this mower.
IMHO opinion it is always a balancing act to turn a good homeowner mower design into a commercial machine as you want to balance durability with the keeping the weight down, so it does not become a tank. I guess we will see what happens.
Do you have any feedback on this machine yet?
I'm interested in how well it has worked for the commercial landscaper?
The only complaint I have about the TimeMaster is Toro only offers the mulching blade for this unit. I'm not a fan of mulching. Each time the blades cut the grass it creates more moisture, which contributes to clumping & clogging the chute.
Standard blades work real well with this mower and create a lot of air movement to blow the grass out the chute, even in taller grass.
For anyone interested I measured the blade speed of my TimeMaster with an optical tachometer. They are running at 4400 RPM. This calculates out to 17855 F/M. :thumbsup:
My dealer mentioned the other day that there will be a commercial version of this mower in 2013 with the possibility of different blades available.
Mac
