lightadjust2000
 - Jul 11, 2023
- Threads
 - 0
 - 3
I'm having this same issue with a 6 year old timemaster, changed oil, new plug, new fuel filter, new blades, new air filter, new ignition coil, new gas cap.  all parts have been oem.  i even dropped the carb and cleaned the bowl (it was spotless anyway).  the symptom ocurrs only when its above 80ish outside...seems i can prevent it by quickly letting go of all handles and letting it run idle for 30 seconds, only to start up again and 5 min later the issue happens much quicker and i cannot prevent it.  if i try to restart, it wont even spit, almost like there is no spark, which is why i replaced the ignition coil.  any more ideas?
