Toro time cutter ss5000
cfoster47
Mower isn’t starting I’ve replaced the seat switch and solenoid and also have a new battery. Every time I turn the key it just clicks once.
You should be able to rotate via the screen on top of the engine.. Or if it's a manual blade engage (you push a LEVER/HANDLE) grab the the pulley shaft under the mower.
Remove spark plug wire if you do this
