Toro SS4225 42 inch deck.
Ken Simpson
Toro SS4225 42 inch, Deck will not go down, stuck in the up position.
matt man
Need to look at the lift system. works like a hinge. and pins. Something isn't align right, or something is jammed. Pretty basic system. Keep looking and you'll figure it out;
Have you released the transport lock ?
On the height adjuster there should be clip of some sort to stop the height adjustment lever bouncing out when trailering the mower.
7394
Timecutter does not have transport lock, just the 4-1/2" range on stick.
To OP: Suggest you set height handle to lower setting 3" or below & wiggle the deck, it can get stuck up high.
