Toro recycler
Fish
Got that problem myself........ If it isn't the shaft seal, then it is likely the engine base gasket, which means you need to pull the engine..
BlazNT
Engine model number should be on a tag attached to engine.
Check to see if the seal between the dipstick tube and the base.
ibeballin23
Thank you, are these difficult to do my self or is there any video out there to watch?
Take off the muffler guard, and muffler. Behind the muffler, you'll see a small rectangular plate screwed onto the side of the engine. This is the access to the valve springs (don't mess here, not the problem), but the plate is also the engine crankcase vent! This cover has a thick cork-metal-cork gasket that has failed. When that gasket leaks the oil dribbles out right where you pictured it. Easy job to do yourself and just a few bucks for the gasket. Be sure the engine (NOT the mower) model numbers are correct so you get the correct gasket. The engine numbers are under the plastic decorative cover on top of the engine, stamped into the fan housing. Happy mowing!
