Toro recycler help
Vitokuz
Newer toro recycler, cleaned carb, only starts with starting fluid but then it smokes and runs hot
Check your oil level and get back to us.
Vitokuz
oil is a bit high, only by a bit
Please post your units model and serial numbers for me. I want to check which engine you have.
Vitokuz
This works?
First, you engine is 9 years old, not a newer mower. I’m going to ask a few questions to get a better picture of what is happening.
1. Have you recently tipped the unit on its side?
2. If yes, was the carb up or down?
3. Have you tried starting and running without the air cleaner?
4. What color smoke and does it clear up after running?
5. When you cleaned carb, did you check float level?
