Toro gts 2 cycle 21" pow-r-drive model 16785 1985 Suzuki 47PE4-1 engine won't run
Hi
I have been working on this mower the last couple of days. It will start with starting fluid. Took out Air filter, cleaned air filter box, put in new foam (not OEM), I drained gas, cleaned fuel tank, blew out intank fuel filter (didn't see an inline filter), Put in fresh 50:1 gas oil mix with about 1/2 oz of Seafoam, Put new spark plug w/ .32 gap, Took off carb bowl and cleaned it, & sprayed carb cleaner in carb. Couldn't figure out how to get cables off carb to remove the whole thing so I just left it alone. Will start with starting fluid for about 2 seconds...then kills...so I am assuming I have spark.
Any suggestions????
Thanks,
Satori
Hi
Any suggestions????
Thanks,
Satori
