Toro Engine Info
The Loncin engines are use quite a bit on Toro mowers and I don't much work on them but other wearable items and electric brake module tends to go out a lot more.
These engines are also built to Toro's specs hence they are rebranded as Toro engines.
This will be a new mower. I have a 60 inch Toro with a Kawasaki engine and need another mower, I will keep the old mower. Better deals on mowers with the Toro engine.
I owned two Toro mowers with the 708 cc Loncin engine. Both of them performed well. However, neither mowers could handle my property. I had to move up to a commercial machine.
Just wondering. Looking to buy 60 inch Toro ZTR. How good is the Toro Engine.
Chinese clone engines are fairly common on small equipment such as push mowers, tillers, snow blowers. However, when moving up in horsepower to 25 hp, etc. I would not recommend them. Kawasaki versus Loncin, LCT, Powermore, etc. is a no brainer. Chose the Kawasaki.
