Toro curb side pickup issue
Bmwz3coupe
20334 electric start with dead battery. Is there a bypass trick to verify the start system good/bad when you have a totally dead battery ? The old battery will not take a charge. I don't want to buy a new battery if the system is dead. The mower starts fine with pull cord. Thank you for your time.
The electric start system is probably the weak link on those Toro mowers. I’ve worked on Toro for 40+ years and my reccommendation would be to forget the electric start system and use as a pull start.
