Toro 826TE ( 2 cycle 2 stage ) starter problem
jkp62
My Toro snowblower no longer starts using the electric start- no response from switch. Is anyone familiar with this problem ? The most direct way to start is to check the switch, unless someone has a better suggestion. Thanks
jkp62
Re: Toro 726TE ( 2 cycle 2 stage ) starter problem
Model correction
Romore
Do you have power at the end of the extension cord? If so replace the starter, they are not repairable.
