toro 6.75 hp GTS RECYCLER
jerry burk
Where do i get an air filter for the Toro 6.75 GTS RECYCLER what wuld make it not run unless you hold the primer in ?
You can get the filter at Home Depot.
Not sure about why it only runs if you hold the primer in.
Hope someone knows because I have one does the same thing.
