Toro 6.5 recycler
What's the model number of the engine? usually stamped above the spark plug into the sheet metal or above the muffler.
it could be an issue with the carburetor you bought, if it was a cheap one from EBay or Amazon. do you have good fuel flow from the Tank to carburetor?
Model 20016. Yes it came from Amazon. Don’t seem to have any obstruction from fuel tank to carb. Jets are clear.
Would not start without starting fluid before changing carb but once it started it ran ok. Now it starts right up but dies under load.
I have the same mower . I replaced the exact carb with a cheap one from eBay. Pump bulb & it starts but dies after a few seconds. I pump the bulb every few seconds to keep it from dying. Then, it kept running. I readjusted the carb & it is fine now.
what carb adjustment did you do?
Adjust the one screw that you see between the air filter & the mounted carb. Like I mentioned, keep it running by pumping the bulb once every time it starts to die. I probably had to do that 15 times before it kept running by itself. You can remove the filter to adjust the carb.
