Hi does anyone know how to remove the moulded impeller on a toro 400 / allen xr44. Its powered by a Honda gxv57. I cannot use a conventional puller and i dont want to be too heavy handed on it as its a steel boss with the impeller moulded around it.
Thanks in anticipation
could you take a pic? my brain isn't working at the moment.lol,if its the blade adapter you might try a bearing separator tool,sold anywhere automotive tools are sold.
Hi thanks for your reply . The impeller is moulded onto an aluminumboss . The impeller cannot be pulled with a pullwr as there is nothing to grip on to. I also cant heat the boss up as it melts the impeller. The internal part of the boss is threaded and the only way o can see working is to attach a slide hammer. Was wondering if any of you guys had any experience. Thanks in anticipation
I am going to give you something to do until someone smarter than me can help,buy a can of penetrating oil,PB blaster or whatever is good in your parts,and everytime you go near the thing spray the shaft at the impeller,after a few days of that you may be able to wiggle it off.i think that is a splined shaft,after all the soaking try a screw driver and rubber mallet and lightly tap the center of the impeler where it touches the shaft,a little patiences will pay off.i hope that helps
