Toro 22" Recycler - Won't start!
marcusvolk
I have replaced the gas, used a mechanic in a bottle, gas stabilizer, a new air filter, a new spark plug, and taken apart the carb, the gas tank and the fuel line to clean. It will start for 2 seconds and then cut out... I am VERY confused... Please HELP!!!
Carefully remove the bolt on the bottom of the carb, try not to remove the goat bowl. This is also the main jet. Make sure that the holes vertically and horizontally are open. If you find a green or brown scum, you may have to rebuild the carb.
I followed the link from another thread and took apart the entire carb, cleaned port I could find and put it back together. Now I can't even get it to turn over ONCE! I have no idea what is going on...
Loosen the bolt on the bottom of the carb (do not remove) you should get fuel come out. No fuel means no fuel in the tank, fuel line plugged, needle is stuck closed. Fuel coming out means the jet or nozzle is plugged.
