Steveog
- Jul 24, 2021
- 5
I’m very close to having my head pop off… I purchased a lawn mower on FB and have:
Replaced spark plug
Cleaned the carburetor completely(all jets blasted with cleaner and air)
Replaced air filter
Replaced oil
Mixed sea foam in with gas
Replaced the brake cable.
Once I got it to run it sounded rough very high RPM. I mowed for about 10 minutes and puff puff POP! It ran out of gas so I put more in and nothing. Checked the carburetor again got a new plug and then sprayed carb cleaner and tried starting it. And now it sounds like it doesn’t even want to turn over. I put my thumb over spark plug hole and got blow back. I checked spark plug and I get a spark. When I try to start it, it doesn’t sound like it wants to turn over and then it makes a little pop sometimes after spraying more carb cleaner. WHAT COULD IT BE?! I have to fix this now out of principal. Please help thanks y’all. I can take video and pics if needed.
Replaced spark plug
Replaced air filter
Replaced oil
