Timing Marks For Kohler XT 7
ryan31
I don't know the marks or where they are could someone help me out pls and thx
The only timing marks on that engine would be on the crankshaft gear and camshaft gear to time those two gears together correctly. the ignition timing is fixed an is set with the flywheel key. so if that key is straight and not broken the ignition is correctly timed.
