jimrs
- Jun 20, 2011
- 5
- 113
I guess its time for a new carb for my Honda. I knew when I bought this mower that this would be a problem as this is my third Honda. It's a HRR216VXA and it ran good for a year then started surging when the blade was not operating. I have let it go sense it ran good with the blade on. This year it won't start I replaced the plug and the old one was was BLACK but it still won't start. I was going to ask what you would do as far as another mower but found that the carb is less than $20.00 so I guess I will either go buy a new carb or take it in and have the mechanic go through this 4 year old mower and make sure it all o.k.
I think that I should take it in and have them sharpen the blades and check out the valves and change the carb so I don't have anymore problems this year. I'm too old and lazy to work on it myself. I get down on the ground and work on something then I can't get back up.
The mower is only used to do some trim work around the house and the front ditch as I use the z-turn for the rest. But it's not fun having to do this trimming with the weed eater.
