720 K grasshopper that turns over but wont start , has weak spark. seat safety switch ok control lever switch's ok and park brake switch ok. How do u put in neutral to push?
Don't know your machine. On my craftsman there is a rod which is pulled out and latched to disengage the transmission ( a rider). Have you tried to get a manual?
the hydro pumps are equipped w/a dump valve located on lower left side toward the front of each hydro pump.activate the dump valve by rotating counter-clockwise w/a wrench.rotate one revolution.....russ
