If i am going to buy a tiller really cheap maybe used what should i get
T tractor man Forum Newbie Joined May 17, 2014 Threads 3 Messages 8 Feb 10, 2015 / tillers #1 If i am going to buy a tiller really cheap maybe used what should i get
reynoldston Lawn Pro Joined May 23, 2011 Threads 92 Messages 5,705 Feb 11, 2015 / tillers #2 tractor man said: If i am going to buy a tiller really cheap maybe used what should i get Click to expand... Your first job would be to find the used tiller. It should run good and have good tines. A tine replacement kit can run about 200 dollars.
T tractor man Forum Newbie Joined May 17, 2014 Threads 3 Messages 8 Feb 11, 2015 / tillers #3 Which tiller do you recommend to get because there are all kinds.
Parkmower Well-Known Member Joined Jun 7, 2011 Threads 23 Messages 891 Feb 11, 2015 / tillers #4 Is this for home or business? What are you planning to do with it? Those questions determines what style you should get
reynoldston Lawn Pro Joined May 23, 2011 Threads 92 Messages 5,705 Feb 11, 2015 / tillers #5 They all do about the same job. The best tiller I ever used was on the back of a small farm tractor that ran off the PTO. It all depends on how much you plan on spending and as said earlier what you plan to use it for.
