My handhelds are fine....i started with a snapper rear engine rider...then a sabre tractor (john deere) ...then a cub cadet z force....mowers that aren't meant for my applications
The snapper rer will do good and handle the hill but it needs to be set up just like new or you will eat up the clutch disk fast. And the decks bend easy.
The junk Deere well it's just junk.
The cub cadet z force I would think would do good even with a stamped deck.
The thing is when you use the cheaper mowers you have to stay on top of things. Only takes a few mins to shoot some grease on a few spots.
I have a cheap mower a cub cadet ltx 1040
70 to 100 yards a week. Gone threw 4 sets of blades 1 deck belt. 5 oil changes. And just did new deck spindles because I hit things.
Have not had to adjust valves. Tires and drive belts are good. Runs and cuts like the day I bought it.
I work it hard but I take care of it.
If you want something you can beat the he ll out of and not keep up with maintenance then it really does not matter what you get.
(( cowboy up and get over it ))
