reynoldston
I really can't tell the different, putting them side by side they look the same. All I can say keep trying what you are doing? maybe bad pulleys? Just telling you what I did to repair the problem.
i don't know if they r different. i'm asking if anybody knows for sure? if there is no difference, i sure don'twant to pay for the brand name. if there is a real difference, please somebody explain it to me.?
The pitch on the belt is different. A belt that is not a snapper belt will not sit in the grove on the pulley the way it should. A snapper belt is made just to fit a snapper pulley. A belt you get from a auto parts store is made to fit most pulleys put will not work good on a snapper or most MTD mowers.
I am thinking maybe you are missing a pin that keeps the belt from jumping off the pulley.
(( racing is the only sport that you need two balls ))
I try to give information on this forum by guessing only. I live in NY state and you live in California and have no idea what your problem is other then what I have found in repairs that I have done in my shop here. You may have a pulley or bearing problem but I hope you have checked that out? I also have no idea what you are using for a belt? maybe a car fan belt? Is something bent or missing? Like the pins that was mention in the pass post? This is one of the reasons I sometimes I don't like giving advice on repairs.
hi all!
i recently picked up an older Snapper rear engine rider mower. if i read the markings correctly, it's from the early 80's. it has a 14HP electric start. there have been a few issues as would be expected with an older model but i have one problem that just continues to baffle me. the drive belt to the mower deck keeps flying off. it seems to be related to when the drive is disengaged. from what i see in diagrams at the Snapper website, all the parts seem to be in place. i think all the correct parts are present. i'm opened to the possibility that i am operating it wrongly.
once i get it running and engaged, the thing works fine. a fresh set of blades are in order, but that will come after i get this worked out. if i need to stop for a moment to clear a path, move a hose , or anything else, and i want to get off, i need to disengage the belt or the safety switch in the seat kills the engine. when i disengage, the belt flies off. if it doesn't get destroyed i can stand the mower on end, reinstall the belt and continue, but, honestly, that process gets real old, real fast.
anybody ever have this issue? got any wise ideas? or maybe a suggestion where to look for operational instruction?
this mower is used enuff that all the original onboard stickers for each control and its function are gone.
D~~~!
:newhere:
Can you post a photo of the top of the deck with the pulley cover removed? Maybe one from each side?
i haven't taken any pics of it yet. give me some time. what do u mean by "pulley cover" all my belts are pretty much out in the open.
