Throttle abruptly does not respond
RhoRidge
3-year-old Troy-Bilt Broncho was mowing as usual, stopped moving, throttle pedal now can be depressed without resistance. What is the mostly likely problem?
Drive belt came off or broke. Will need to look up inside the frame to determine exact cause.
It's a given: you don't have the non-functioning equipment to examine. Nevertheless, your "diagnosis" is most helpful. Thanks. RhoRidge
