PTmowerMech
- Apr 16, 2018
- 396
- 3,020
Thought zips were nylon. Or maybe the ones I bought for work were? Was looking for outdoor UV rated zips.
Think you meant HDPE, high dens poly ethylene. Simple typo.
Everything looks good other than the nylon black zip tie for a filler rod. I've used zip ties as a filler. Yes it works like in the video. As in metal welding, best to use the same material as a filler rod. I used black zip ties to fill in my Maruyama trimmer fuel tank seam. Still no leaks for 3 seasons now. I leave 2 stroke gas in her all year round.
Agreed, thanks for the video.Thanks for the Plastic welding info. Been doing plastic welding for awhile.
Have all sizes and kinds of electric soldering irons and tips.
Some are also propane heated.
I like the idea of using coax braid as a reinforcement. I have all type, sizes and kinds of coaxial cables so as to get the braid, copper, stainless steel, etc.
Coax cable is an easy grab for me. We have miles of it at work.DO NOT USE PLAIN STEEL WOOL as it will rust
