olgeezershonda
In the meantime maybe this will help:
Quick bolt on. Takes about 20 minutes. Take picture before so you know where to reconnect the governor rod and spring. No big deal.Just a quick question on the carb. When you put a new carb on this mower, is it a simple bolt on replacement and your ready to go or are there adjustments to make after you replace it?
Thanks for the update. It will help others looking to solve a similar problem. As for your diagnosis you could be right.I think I finally have the mower repaired. I should explain what went on. As I said in the beginning of this post I replaced the thermowax module and the choke control. That did not cure the problem of not starting. I mentioned somewhere that it looked like there was a flooding condition because every time I opened the air filter housing there was raw gas laying in there and weeping down the housing. I ordered a new carb because parts for the carb were more costly than just getting a new one. I got the new carb and it was damaged. They sent me another one. This all took time and by the time I got around to installing the new carb a few weeks had passed. By the way. I ordered the new carb from "Boats.net". They treated me like a king. Two days from when I notified them I had a replacement carb. They didn't even want the damaged carb back. I would not be afraid to purchase anything from them in the future. I installed the carb and the mower starts on the first pull and there is no flooding condition evident. As I think this through, I think that there could have been a problem with the float valve leaking in the carb which would have allowed fuel to leak by and flow down and cause the flooding problem when trying to start the mower. That's just my own opinion of what might have happened. Thanks for all the input from everyone on this issue.
