jakesmurray
Update! Spent the afternoon replacing the original ball and socket steering joints with heim joints that I picked up at O'reilly's. Now I have tighter steering, and a little toe in, as opposed to the toe out that I had before. I also replaced the front steering linkage with a straight across bar, opposed to the curved one that was originally on the tractor (to accommodate the front deck support). That means more ground clearance.
I got to try out my new Lincoln welder in the process, it worked great!
