tecumseh ohv155 204509f carburetor
velox73
hello all i am needing to replace my carb and with my engine model i searched and found one that says its
supposed to fit but what i am not understanding is why does it have a fuel solenoid when the one i took off didnt?
it does have a wire coming from the harness that isnt in use but the solenoid has 2 prongs on it so if this is the carb i need
what hooks onto the 2nd prong and where will it be coming from?
can someone verify what carb i am supposed to have on this engine?! TIA
BlazNT
Part Number 640330
Solenoid is electrically isolated from the carburettor for obvious ( big bang ) reasons.
One wire is te + from the ignition and the other is an earth.
AFAIK it is not polarity sensative so you will need to add an earth wire.
velox73
Thank you for the replies hopefully I can get this bad boy running again.
