Ive been having this issue for a while now and cleaning out the carburator and doing the carb repair kit thing didn't help. Spark plugs and filter have also been replaced. The issue is when I first crank it after a 4 push prime, the mower will start only to quit about 1 minut later. This scenario will repeat itself about 4 to 5 times. Afterwards it seems to run fine except when I start mowing longer grass and it starts to bog down and quit. I think I may have to bring it in for repairs but not sure if just buying a new mower would be a better idea unless someone here can help me troubleshoot the issue. Would love to have this thing working like new without having to pay too much.
Update: I redid the carb cleaning and still the same issues. Also tried without the gas cap on to see if the cap vents were clogged up and still stalling. Only thing I can think of now is maybe the coil needs to be replaced. Anything else I may be missing ?
