Toro recycler 22
engine spins easy as shown:
This is the cylinder head, and walls which looks good to me: https://www.youtube.com/shorts/GHeJbSIiujM
I am assuming its the governor spool, and gear assembly, crankshaft or camshaft causing the issue.
I just opened it up, and everything looks good, but took forever to separate the engine. I am assuming the crankshaft is bent, but not sure how to tell.
Inside the engine:
Inside the engine:
