Ok, now I’ve got a better idea of what you are working on. I haven’t seen one of these setups in over 20 years. From what you are now saying I think you are looking for either a stator or stator coil needed to charge the battery, not the magneto which is used to produce spark forthe ignition system. Have a couple of questions. Can you supply us with the spec number for your engine so we can figure out exactly which charging system you have? Have you gone through the troubleshooting procedure in chapter 6 of the manual I posted? If you have please post the results of your findings, so we have an idea how to help you out. Unless you can better describe exactly what you are looking for it will be very hard for any of us to provide help. Please remember that this engine, with this setup, has not been produced in over 20 years and only the older tech on this site have ever seen one. Any pictures you can supply us will also be of a great help.
