- Sep 24, 2017
- 277
- 6,740
Installed new points and condenser, now I need help timing the ignition
I have The piston at 080 before TDC, at this point, the points have the 020 gap between them, I saw a guy use a test light going on and off for the firing of the points, he said that right when the light goes off is where you want to set it. I do not have a test light but I do have a multimeter with the "beeeeeep"
setting, so I'm using it as a substitute, but nowhere in the adjustment of the piece do I get a beep no beep.
This is my first time ever working on a points and condenser engine, so any other ways to do it will be very appreciated. I have watched multiple videos even one that tecumseh made, and.. Well..:confused2:
