MowerTedII
I have a Tecumseh 4HP won't start ! I checked spark with one of those inline checkers. You can see the light go on when you pull the cord .
I pulled the Champion J19LM plug out and it was wet. Cleaned it with break cleaner , put it back in , pulled cord ... NOTHING ! Usually you get something from using break clean ... nothing ! So I have a bunch of mowers around that use the same plug. Put them in and nothing ! It ran last year when I put it away. Even pulled all the fuel out ! I tried spraying brake clean the carb ... nothing !
Any ideas ?
THANKS !
Any ideas ?
THANKS !
