Is this it? TB360?
S slomo Lawn Pro Joined Jul 14, 2019 Threads 80 Messages 5,493 Oct 5, 2022 / TB360 Rattles when running until I pull on rope to tighten then stops #11 Is this it? TB360?
S Swordfish80 Member Joined Oct 3, 2022 Threads 1 Messages 10 Oct 5, 2022 / TB360 Rattles when running until I pull on rope to tighten then stops #12 Yes that is
S slomo Lawn Pro Joined Jul 14, 2019 Threads 80 Messages 5,493 Oct 6, 2022 / TB360 Rattles when running until I pull on rope to tighten then stops #13 Remove the plastic shroud and possibly the pull starter housing. Exercise the pull starter a few times OFF the engine. See what is making the noise.
S Swordfish80 Member Joined Oct 3, 2022 Threads 1 Messages 10 May 7, 2023 / TB360 Rattles when running until I pull on rope to tighten then stops #14 I finally got my lawn mower running after changing the carburetor. Here is the rattle. It might just be the pull start.
S Swordfish80 Member Joined Oct 3, 2022 Threads 1 Messages 10 May 7, 2023 / TB360 Rattles when running until I pull on rope to tighten then stops #15 Swordfish80 said: I finally got my lawn mower running after changing the carburetor. Here is the rattle. It might just be the pull start. Click to expand... All my videos are too large
S Swordfish80 Member Joined Oct 3, 2022 Threads 1 Messages 10 May 7, 2023 / TB360 Rattles when running until I pull on rope to tighten then stops #16 Swordfish80 said: All my videos are too large Click to expand...
S Swordfish80 Member Joined Oct 3, 2022 Threads 1 Messages 10 May 7, 2023 / TB360 Rattles when running until I pull on rope to tighten then stops #17 Would someone feel comfortable emailing me so I can shoot you the videos?
