TB30 30 inch rear motor (4 menthes old)13B726JD066
germanlou
Hello everyone, I bought this riding mower in April. I used it for 3 menthes and then I went out to use again but no power. Yes it's under warranty but i live very rural. Finding a way to LOAD mower on pick up or trailer to drive the mower 70 miles to be repaired is a nuisance, so if i could fix it here that would be great! Any help greatly appreciated thank you.
The mower just stopped starting, I did all the trouble shooting from the manual, nothing. I have charged the battery. I have been literally looking on line for hours for something to help?
Is this a common problem with this mower? Can anyone direct me to a solution to try please.
Thank you!
Try this troubleshooting procedure and let us know what you find.
Electrical problems can be very easy or very difficult, depending on four things.
1. How well you understand basic electricity.
2. What tools you have and know how to use.
3. How well you follow directions.
4. You don't overlook or assume anything and verify everything.
Remember we cannot see what you are doing. You are our eyes, ears and fingers in solving this problem. You must be as accurate as you can when you report back. The two basic tools we will ask you to use are a test light and a multi-meter. If you have an assistant when going through these tests it would be very helpful. These steps work the best when done in order, so please don't jump around. Now let's solve this problem.
First, check the fuse(s), check battery connections for corrosion (clean if necessary) and voltage - above 12.5 volts should be good. Check and make sure the chassis ground is clean and tight.
Second, check for power from the battery to one of the large terminals on the solenoid. One of the wires is connected directly to the battery and has power all the time so one of the large terminals should light a test light or show 12 volts on a meter at all times.
Third, check for power at the small terminal of the solenoid while depressing the clutch/brake pedal and holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch). If your solenoid is a four wire solenoid, check both small wire terminals as one is ground and the other is power from the ignition switch. If your solenoid is a three wire solenoid, make sure the solenoid body is not corroded where it bolts to the chassis of the mower as this is your ground path back to the battery. If in doubt, remove the solenoid and clean the mounting area down to bare metal. If there is no power to the small terminal then your problem is most likely a safety switch, ignition switch or in the wiring.
Fourth, check for power on the other large terminal of the solenoid while holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch).
Fifth, check for power at the starter while holding the key in the start position (assistant again).
Sixth, check your ground circuit back to the battery.
After you have gone through each of the above steps, let us know what happened when you did each step. At that point we will have great info to tell you how to proceed. Remember you are our eyes, ears, and fingers, so please be as accurate as possible.
Be as specific as possible with voltage readings as this will help diagnose your problem quicker. If you do not know how to perform the above checks, just ask and I will try to guide you through it. Youtube also has some videos and as you know a picture is worth a thousand words.
germanlou
so Basically dont buy things that you cant fix yourself when you live 60 miles from repair options. Thanks anyway
Hammermechanicman
Is the battery good?
Is the 15A fuse above the battery good?
Is the PTO disengaged?
Is the shifter in neutral?
Is the mulching shield in place properly depressing the safety switch on the deck?
