I tried to remove the 8 inch drive wheels on my TB230 self propelled mower.
Removed the locking nut at the end of the shaft in the center of the wheel.
Applied pressure, even tried using a tire iron to pry off the wheel.
Thought about trying to spray some PB Blaster on the shaft but it probably won't get in far enough to loosen the wheel from the axle.
What do you suggest I so next?
