How would I put a tachometer on my Grasshopper 725D? Thanks for any answer
C cambre Well-Known Member Joined Aug 2, 2014 Threads 66 Messages 324 Aug 18, 2015 / Tachometer #1 How would I put a tachometer on my Grasshopper 725D? Thanks for any answer
Carscw Lawn Pro Joined Aug 11, 2011 Threads 66 Messages 6,375 Aug 18, 2015 / Tachometer #2 cambre said: How would I put a tachometer on my Grasshopper 725D? Thanks for any answer Click to expand... Red to power. Black to ground. The wire that you would hook to a cars coil hook to the coil kill wire.
C cambre Well-Known Member Joined Aug 2, 2014 Threads 66 Messages 324 Aug 18, 2015 / Tachometer #3 Thanks Carscw: Are you talking about battery and ground off of the ignition switch, battery, or other component? Thanks for the answer.
Carscw Lawn Pro Joined Aug 11, 2011 Threads 66 Messages 6,375 Aug 18, 2015 / Tachometer #4 cambre said: Thanks Carscw: Are you talking about battery and ground off of the ignition switch, battery, or other component? Thanks for the answer. Click to expand... You can run the power off of the key switch. I used the wire going to the bottom of the carb. The ground you can put anywhere.
C cambre Well-Known Member Joined Aug 2, 2014 Threads 66 Messages 324 Aug 18, 2015 / Tachometer #5 Thanks for the help Carscw. I think I can do it now. Cambre
