cpolarbear
- Sep 8, 2017
- 1
- 8
My T2500 has started leaking fluid out one of the transaxle wheel shaft seals. It appears the unit has no orifice to be able to add axle fluid/gear oil to top it off. I have been unable to find any info on the transaxle to research, specifically which part number applies to the axle to look for repairs or replacements. Can anyone assist in locating the part number of this unit and if I can replace the seals and top off the fluid? It has made the tractor very iffy to go in reverse, and only okay going forward. Runs great otherwise, the Kohler engine is smooth and strong.
