wiring plug layout is different, command engine has solenoid on starter.
J Johnjustjohn Forum Newbie Joined Dec 28, 2015 Threads 2 Messages 3 Dec 28, 2015 / swap 2004 26hp kohler command engine for later model 27 hp courage, wiring? #1 wiring plug layout is different, command engine has solenoid on starter.
reynoldston Lawn Pro Joined May 23, 2011 Threads 92 Messages 5,705 Dec 28, 2015 / swap 2004 26hp kohler command engine for later model 27 hp courage, wiring? #2 Johnjustjohn said: wiring plug layout is different, command engine has solenoid on starter. Click to expand... You will just have to rewire the engine to the tractor. All a starter solenoid is, is a heavy duty on and off electric switch no matter where it is mounted. You should be able buy a starter solenoid form any auto parts store for the courage.
