Bhauck
- Jul 22, 2021
- Threads
- 3
- 9
Hello, I need some help. I have a new to me JD stx38 yellow deck. It had a no start when hot issue. Traced it down to a faulty neutral safety switch. After replacing the neutral safety switch the mower will only start when place in reverse gear. All gears on shifter correlate to there respective gear on the transmission, so when i start it in reverse the mower is actually in reverse gear, not neutral. Any idea why this is happening. Did i install the neutral switch wrong, could it be the wrong switch, or is something in the transmission broken. One more thing, on the old faulty switch. The side that is actually in the transmission was very rusty, is that normal? Thank you in advance for the help.
