Stuck transaxle on JD160
Now I tried a penetrating oil called Free All. Claimed to work on every struck screw and was guarantee to do so. That is BS and they would not honor the guarantee. Also said it dissolve rust yet again more BS. I have better luck with Muriatic Acid if just cleaning steel screws or using some the gun cleaning rust remover otherwise.
Hi, Star Tech, In fairness to that FreeAll penetrating fluid. I have used that in the aerosol can and twice now over the past dozen years I had the experience of unable to loosen a steel fastener (nut and bolt) and a brass nut and a steel screw. I had given up after a couple of hours so I saturated them , said I would let them set overnight and if they did not loosen was prepared to just break the screws. I went out the next morning and the nuts were so loose I was able to unscrew them with just my fingers.
Now I know , Star Tech ,if anyone had told me this story I wouldn’t have believed it but it happened to me.
I am really surprised that FreeAll did not send you a new can of the product. I was so impressed with the product that after the first experience I ordered a case (12 cans ) (much cheaper)and have gifted them to friends who have helped me. They even sent me a free replacement can when the valve malfunctioned on the aerosolize can. They also made a non aerosol version which I did not think worked as well.
Star Tech keep doping what you do……I have picked up a lot of useful tips from your posts!
