cfmechanics
 - Mar 7, 2012
- Threads
 - 5
 - 37
Yes, I am using steel on steel - I take it that's not a recommended way of doing it. I have heated the bearing but still no luck. I can cut it with a grinder though if you think that's a good idea, I am replacing all the bearings anyway.
I can't use a vice because the shaft is stuck on the deck until I get the bearing off unfortunately.
I totally understand what you are saying. It has come very apparant that you need more than a couple of tools to do this job with. I will continue to work on it and hopefully it will be off soon.
This thread and everyone who has commented in it has been very helpful and I am grateful of that.
Thanks everyone! :smile:
