pugaltitude
That's very interesting to know. So do you know when it was phased out so I know for the next deck restoration I do?
Thanks.
No ignore that last one.
just checked and its available 」20 + vat each.
Never replaced one though.
Thanks.
Westwood mowers aren't common here in the USA and 2 piece bearing housings are probably less common. That's interesting enough to me I'd sure like to see a picture of the 2 piece housing if you have the time.
So I'm guessing here the bearing races of both bearings contacted the deck? If not, is there a tubing spacer between the bearings inner races?They have stopped making them years ago. They have gone to a single housing now.
It was a tin housing that had a bearing and sat on 1 side of the deck and another housing that was on the other side of the deck with a shaft through the middle.
I think I'm gonna have to have a good picture of that. My imagination is blank on that one.:biggrin:Right, I have just had another go at getting the bearing off using everyones suggestions and I have just found out that on the shaft there is a very small lip which is stopping it from coming off. Does anyone know how I can get it past this lip and also when installing the new bearing how to get it over the lip again?
Thanks
I'm thinking there is a corrosion problem between the inner races and shaft. All I've worked on of this basic style the shaft to inner race fit was a slip fit.
