ChaplainJeff
I have a Troy-Bilt (126T02-0675-B2) push lawn mower with a Briggs and Stratton Model 120000 engine. I can't get it to start. Suspecting the spark plug, I connected my ignition tester from the ignition coil boot to GROUND on the engine block. A spark in the tester gap tells me that the inductor coil is producing current. Removing ground and clipping it to the spark plug shows no spark. Easy... bad plug, right? Well, I replaced the plug and got the same indications. Used a second new plug and still no spark. Only when connecting tester between the spark plug boot and block ground do I get any spark. I am totally stumped. Please HELP! :confused2:
