Still having fast idle when engine is warmed up. Cold idle is normal.
What is the model, type and code of your engine????????
As star tech mentions in post 5 the governor idle adjustments have to be correct. If you make these adjustments with a bad carb it just makes things worse.
AND
I've seen Nikki carbs have those symptoms and most generally it is the Clone Nikki's types.
Wondering if you have ever seen this engine carb combo operate correctly?
Did it just start doing this all at once or ?????????????
This happened gradually over time and seems like it’s getting worse. Nothing has been tinkered with as far as governor adjustments….only backed the idle adjustment down. I did remove , clean, and replace the intake to insure that it was sealing properly, but that was after it had already started doing this.
I think I must have overlooked the request for this information. The first vide is cold start up and run. The second video is after fully warmed up from cutting grass for 15 minutes. 864FFFC1-2B92-492A-BE6F-71CA5B51D4C1.jpeg
HMMMMMMM
Dual throat Nikki carb. I've seen the o-rings inside those Nikki carbs cause that engine speed changes.
I did not say that carb is your engines issue but it's a good suspect.
Here is a link to review about your 796997 Nikki carb. (repairs, etc)
Here is some info I have saved from my files about those type carbs FOR YOUR REVIEW.
Nikki dual throat carb repair/rebuilding links
Nikki dual throat carb tips and re-building LINK.
Guy asks about jets sizing and re-building a dual throat Nikki carb
https://www.lawnmowerforum.com/threads/nikki-dual-carb-main-jets.29187/
You tube video part 1: (newer style aluminum float bowl Nikki) USE KIT 54832 @ $7
part 2 (older model with steel float bowl) USE KIT 54833 or 54834 @ $9 each depending on the style of Nikki. See part 2 of the video to determine which kit needed.
