pugaltitude
Its not something you hear of much these days seizure from lean mix.
Yes engines do run leaner to compensate emissions which then make engine running hotter but cooling systems have been adjusted to suit this.
I would say mix has not been right at one point and basically through usage it has finally worn out.
