Can't get this trimmer started:
Took out spark plug to check to make sure there was spark and YES there is.
Looks like there's fuel getting into the cylinder because plug looked wet.
Took spark arrestor out and looked dirty and haven't put it back in yet.
Inspected air filter and didn't look to bad.
Drained fuel and put fresh mixed fuel from gas station and put a brand new spark plug.
After changing the spark plug with a new one and adding fresh fuel and keeping the spark arrestor out it still wont start. I double checked to make sure the plug has spark which it does and can pull many times with the choke on and i can see fuel spitting out of the exhaust and still not even a hint of combustion. Prior to this the last few times it seemed like the primer bulb wasn't working right as it wouldn't fill up with fuel but this time it seems like it is. When I press it down and release it, it fills up with fuel.
After a couple of times of trying and flooding the trimmer I would remove the spark plug and dry out the chamber with short bursts from a propane torch and try it again but still nothing.
