goosemasterkl
bertsmobile1; how do I go about matching a coil with a flywheel? How do I test the stock/old coil to see if it's bad? Thanks
That would be because the Briggs cast iron crankcase has a positive ground system. But it is worth that the aluminum crankcase are negative ground so if you put the coil on them upside down they will misfire due ignition timing. So the only time you need to flip the coil on an old Briggs engine would when a cast iron crankcase is involved.On the old points briggs engines if you are fitting a modern coil with a chip, you have to turn it upside down .
I just wonder when people a going to learn, when you order aftermarket parts, there is a very good chance that what you order WILL NOT WORK. The aftermarket markets don't have the all the factory specs on ALL the parts.....there are too many different changes in parts. There can be 10 different parts for the same # piece of equipment and are specific to a certain model & serial #The position of the magnets looks the same don't they? It's an aftermarket coil; but the old one looks the same way.
That is why I posted this update, because there are not only different coils, but also the slot for the flywheel is in different versions of the crankshaft, etc....I just wonder when people a going to learn, when you order aftermarket parts, there is a very good chance that what you order WILL NOT WORK. The aftermarket markets don't have the all the factory specs on ALL the parts.....there are too many different changes in parts. There can be 10 different parts for the same # piece of equipment and are specific to a certain model & serial #
But just how does the batteries recharge and how many do needed during the cutting 3000' ft fence line 4'-10' on each side? I usually go through 1 to 2 gallons fuel mix per cutting along multiple refills of trimmer line.
Did you ever figure this out? I'm having same issue.. new carb.. new seals.. spark arestor clean. Acting like timing is of.. flywheel key ok.. tried new ignition..I'm working on a Stihl FS 38 trimmer that a friend said he couldn't get it started. I checked the compression and it had 90#. I then checked the spark and it was kinda eratic so I put a new coil and flywheel on it Finally getting a spark but still won't start. I then put on a new cylinder with new piston and rings now it has 120# of compression. But still won't start; doesn't even try to hit. I then put on a new carburetor; still nothing. It has kinda of backfired out the carburetor a couple times but that is as close as it gets to even making a sound of starting. It won't even hit using starting fluid. I'm stumped; I put everything on it new that I can think of. Somebody give me some ideas please. Thanks in advance to anyone who responds
