You might need to brush up on HOW to use thread locker friend. You don't just glob it on, over torque the screw with your impact gun and call it good. Then come on here whining about how your muffkin fell off.
1.Over torquing CAN warp said muffler so it MIGHT fall off doing this. Was yours rusted out like the one in the video MPARR posted? If so DUH!!!!
2.You need to CLEAN the screw and engine block threads PRIOR to adding the locking agent. Maybe a tap and chase some threads? Little brake cleaner to CLEAN the threads. Then........
3.Permatex makes a primer we are all supposed to be using before applying the locking agent. I don't use it either. BUT, if you are using red and it falls off......
4.We must SHAKE the thread locker prior to using as the label states. Also thread locker has a shelf life. Also some brands like HoboFreight or Loc-tite don't make good locking compound IMO.
5.One drop of locking agent per screw and screw hole threads is ALL you need. Torque to factory specs. Blue should be all you need. If red was installed correctly, it will/can brake screws, ratchets and sockets.
Here is a video on the primer and the locker.
