Tommyb2401
Got a bg55 that won’t start. Was running rough but would run then nothing I have changed the carburetor the fuel lines and filter, the coil and plug also cleaned the spark arrestor. I’m lost
Did you replace the cylinder and piston as well. Sounds like that is about all you missed. What you have to have to run is fuel fire and compression at the right time. Sounds like you have the first two how about the last one compression. Quit throwing parts at it and hope you find the right one. Diagnose the problem, 95% of any repair.There are other things that can stop a 2 stroke from running like air leaks.Funny thing about a 2 stroke is it actually has two parts to the engine to get it to run. The bottom end is a pump and the top end is the engine. If the bottom end is not sealed and can draw mixed fuel and air into the crankcase vie the carb. and pump it to the cylinder and piston it will not run properly or at all . Air leaks like seal, gaskets and sealer in the joints in the engine. Do not run a two stroke engine that is not running right the only lubrication it gets is in the mixed fuel it gets and if it is running lean it is not getting proper lubrication. Results is a scored cylinder and piston and low compression. Just trying to get you to realize there is more to repairing any kind of equipment than changing parts. If that is what we who actually do this for a living we would not be in business very long.
Guys like me could probably have just pulled the starter rope and told you whether or not it was worth fixing. And might have saved you money in the long run.See I have don’t a compression test and was reading normal numbers. I’m not throwing parts at it I’m doing process of elimination. No I don’t do this for a living no do I want to but I don’t want to pay the guys like you that do it for a living 80 an hour for labor either. So here I am asking on a form for help not a lecture. But I will take what you said and learn from it.
