AlabamaDan
I couldn't sleep so I went out to the shop. I cleaned the frame underneath the motor and tank and down the exhaust side of the motor. What a mess.
I checked the diaphragm again. That little disc is metal so it should be rigid, however it all is and shouldn't be. All the black rubber should be as soft as silk from what I've researched. That's definitely an issue.
I emptied the tank and checked it out. I appears good and clean and doesn't appear to be leaking.
I reassembled the air filter housing, carb, pull starter etc. Basically everything except the muffler and plastic cover.
I pulled the plug and I checked the compression on the cylinder three times: 75, 80, 80. I would think that's good compression. Before checking the compression I laid it down and pulled it a bunch and no gas or anything came out any holes. If it was overly flooded, it's good now.
When it warms up I'll put some fresh gas in and try to crank it (no choke) without the muffler and see what happens.
