This might be more of a rant but it does involve questions.
Blower was losing power then died. Would not restart. Took it to local dealer. He said primer bulb needed to be replaced. I told him to fix that and adjust valves. Calls be back and said it needs a push rod. Ok fine. Then calls me and said someone before them over tightened the nut on the crank, and it broke while getting it off. Why would u remove this to install push rod?? Who would be responsible for replacing the crank? Opinions or suggestions
